its been a while but i need a tire size opinion
Old Nov 24, 2008 | 06:54 AM
one_fast_300zx's Avatar
alright it feels good to back here. don't have a computer at my place so i have to use my dads. anyway i want to put 17x8's up front and 17x9.5 in the rear of my 300zx. i have looked at tire sizes on the z31 wheel-show and seen what other people have used for sizes of tires for that size wheel but i want your guys' opinions as well. what size tires would you use? also thinking of using maybe a 1" spacer just to bring them out some. thanks in advance for the opinions.
Old Nov 24, 2008 | 08:33 PM
mrbillishome's Avatar
kinda of off topic but what is the offset for the z31 jw? sorry for the thread jack
Old Nov 25, 2008 | 08:03 PM
AZ-ZBum's Avatar
It's really stupid to say you're going to get 1" spacers when you don't even have the wheels and offsets yet. If you buy wheels with the appropriate offset, you'll never need spacers.
Offset vs Width information:
http://www.az-zbum.com/information.w...nd.tires.shtml
Old Nov 26, 2008 | 12:15 AM
thanks azzbum
Old Nov 28, 2008 | 06:42 AM
zbum, here are the specs for the wheels im looking at what do you think?
front
Wheel Size 17x8"
Wheel Height 17"
Wheel Width 8"
Offset -11mm
Bolt Pattern 5x4.5"
Back Spacing 4"
Finish Polished
rear
Wheel Size 17x9.5"
Wheel Height 17"
Wheel Width 9.5"
Offset +28mm
Bolt Pattern 5x4.5"
Back Spacing 6.375"
Finish Polished
give me your professional opinion on if i should use spacers and what size tires you would go with. i consider you to be like a z31 guru. thanks in advance.
Old Nov 29, 2008 | 07:46 AM
AZ-ZBum's Avatar
Is that a minus 11 on the offset? If it is, they'll likely stick out past the fenders as they are. You might get away with them if you get stretched tires (I personally hate the look).
The backspacing numbers don't exactly match the given width/offset information, so I'm not sure which numbers to believe.
No matter the case, you will not need spacers or adapters. They're a pretty aggressive fit and will probably work well on an AE or 86, but not too sure about the 87-89 models. I'm skeptical about them fitting the front properly. If they're local, you should see if you can try them on first.
Old Nov 30, 2008 | 10:12 AM
thanks zbum. yea its a local place i would be getting them from. but knowing my luck i would have to order them before i could test fit them. i got the specs right from the site of the local place that i would go through, here is the link,
http://sedamtire.com/showcaseproduct...=109&Type=2640
they got specs for all the different sizes you could get them in on there. the place is only like 10 mins from me and i know the owner so i may be able to test before purchase but he can be a ***** at times so its hard to say.
they wouldnt be going the 87 N/A i got, come february i will have an 88 turbo if that makes much of a difference.
Old Nov 30, 2008 | 03:15 PM
AZ-ZBum's Avatar
Of those options, you should easily be able to see the choices I would make.
Front: 17x8
Wheel Size ------ 17x8"
Wheel Height ---- 17"
Wheel Width ----- 8"
Offset ---------- +8mm
Bolt Pattern ---- 5x4.5"
Back Spacing ---- 4.75"
Finish ---------- Polished
Rear: 17x9.5
Wheel Size ------ 17x9.5"
Wheel Width ----- 9.5"
Offset ---------- +28mm
Back Spacing ---- 6.375"
It doesn't.
Old Dec 1, 2008 | 03:47 AM
oh i didnt even see the 17x8 with the +8mm offset i will go with those ones thanks for noticing it zbum. i probably was just skimming through looking for the right bolt pattern and that was the first one i seen. so back to my origanal question now, what size tires would you put on those wheels on the 88 turbo?
Old Dec 1, 2008 | 04:16 AM
AZ-ZBum's Avatar
See the link I already posted.
Old Dec 6, 2008 | 07:02 AM
so would you say 235/40 up front and 255/40 in the rear would be fine then? sorry it took a while to post back been so busy at work i havent had time for much.
Old Dec 6, 2008 | 10:19 AM
AZ-ZBum's Avatar
I would go wider on the rear. I have 255s on the 9" wide wheels and will be going wider next set.
Old Dec 6, 2008 | 10:48 AM
so 265 275 maybe would be a better choice then?
Old Dec 14, 2008 | 05:48 PM
Racinjitter's Avatar
^ yes, on a 9.5" wide wheel I would go with a 275 or wider. 275 is a perfect fit on my 9.5" wide wheels.
malibud
Oct 9, 2012 02:27 PM
BlueKitsune
Jul 16, 2009 11:06 PM
BigRich
Jul 19, 2007 03:33 PM
Fast240Z
Jun 1, 2005 12:58 PM
Lazerus
15
Nov 6, 2003 11:35 AM
