Hood won't open.
Old Mar 5, 2010 | 10:10 AM
wals's Avatar
Hood won't open.
I bought a 88 300zx in Ca.last week. Got it home and now I can't get the hood open, any sggestions ? seems like the cable is stretched. Walter
Old Mar 5, 2010 | 11:05 AM
Have someone hold the hood release all the way open.
While it is pulled, another person should use their fingertips or the head of a screwdriver to carefully pry the hood up. A lot of times it is just sticky and won't pop up that first little bit on its own.
Old Mar 5, 2010 | 02:51 PM
wals's Avatar
Thanks for your reply,I tried that and still no go, trying to think how I can spray some oil on the latch,let it soak, then try again. thanks again.. Walt
Old Mar 5, 2010 | 07:31 PM
TeamRonin's Avatar
PB Blaster is some awesome **** to use! Its awesome to break things free. I use it all the time. After ya break it free try to clean it all up and spray it with some white lithium grease. That stays lubed and working free through all the elements. Great stuff!
Old Mar 6, 2010 | 12:06 PM
wals's Avatar
Thank you for the input will try that.. Walt
Old Mar 6, 2010 | 07:10 PM
TeamRonin's Avatar
let me know how it goes. I do have another trick up my sleeve to open it if ya cant get it.
Old Mar 7, 2010 | 06:37 AM
wals's Avatar
I will let you know how it goes, laid up right now.. had eye surgery on the 2nd , then strained the stitches, hate just laying around. thanks again. Walt
Old Mar 8, 2010 | 09:22 AM
If the cable is completely broken then you have other issues. If the cable is stiff or pulls the latch but the hood won't pop, then my suggestion helps fix that.
Old Mar 11, 2010 | 05:05 PM
wals's Avatar
Still can't get it open, cable is in tack, think latch is just frozen. will try more pb blaster..
ueharamotowerks
Feb 21, 2007 02:53 PM
Heat Rave R
May 2, 2006 10:57 AM
FubarI33t
Aug 25, 2005 05:30 PM
SunTadZ
Jan 4, 2002 08:46 PM
