Help!!!
Old Jun 13, 2002 | 03:29 AM
Spot's Avatar
Re: Help!!!
the idle switch is on the drivers side of the upper intake collector. it's about in the middle and has an electrical connector going to it. i don't remember if it's a 2-wire or 4-wire connector though.
You should be able to find a pic of one in the Haynes manual.
If you don't have a Haynes, pick one up - it'll be the best 16 bux u ever spent on your z.
Be wary of Chiltons, I've got both new and old ones and the only use I've found for them is as a doorstop.
