Headlight and Turn signal issue
Old 04-05-2013, 07:54 PM
Dan
Dan's Avatar
I have a weird problem, i just but in hid projectors in my 1987 300zx. They work perfectly fine, i decided to take it for a spin to see what the HIDs look like on the road, but then my right turn signal didn't work, left one works fine. when i turn my headlights off, both turn signals work perfectly, its only when the headlights are on that the right side fails yet the left side still works.....really really weird, any suggestions?
Dan is offline
Old 04-05-2013, 08:27 PM
PredatorZ's Avatar
recheck your wiring
I'd say you might have a common and hot mixed up, so when your lights are on the turn signal is shorted, when its off the signals work fine.
PredatorZ is offline
Old 04-06-2013, 06:40 AM
Dan
Dan's Avatar
Just tried that.....didn't seem to work, i know its not a HID related thing anymore. I put my halogens back in to see if it was an HID problem, but its not. I think i might have touched something while i was doing the "sleeper eye" mod. Where you just unplug the headlight motor wire under the steering column. So i reconnected it, but still nothing. when the engine is off and head lights are on, the right side turn signal blinks slow, left side works fine all the time, engine off and head lights off, right side works fine. Engine on and headlights off same thing, right side works fine, but right side engine on and headlights on, right side doesn't work at all.
Dan is offline
Old 04-06-2013, 06:41 AM
Dan
Dan's Avatar
I went and checked all the connection under the steering column and everything looks fine
Dan is offline
Old 04-07-2013, 07:24 PM
michealtheworm's Avatar
Maybe a wire is getting pinched when the lights come up or it is shorting something out. Retrace your work slowly and carefully. They worked fine before right? I thinking its in the engine bay and not at the column.
michealtheworm is offline
Old 04-09-2013, 04:40 AM
reddzx's Avatar
XenonZ31 Headlamp Problems
reddzx is offline
Thomas Ward
04-20-2014 09:09 PM
skygunner58203
09-28-2013 03:48 PM
tennis280zx
04-01-2013 02:34 PM
gdcat51
06-27-2009 12:15 AM
Quick Reply: Headlight and Turn signal issue
