Headlight bright
Old Apr 8, 2013 | 09:51 AM
mr.chris's Avatar
Headlight bright
Hey all my name is Chris I'm new on the forum but not new to it, I've owned a 1985 zx for two years now and have referenced the site on numerous occasions. I have had this problem since I bought my car. My right headlight bright does not work and I've put in new lights, relays, etc but it still doesn't work. I'm sure ill just end up having to trace down a short In the wiring but I figured Id ask for a possible simple fix. Thanks and ill be posting pics when I get on a computer!
Old Apr 8, 2013 | 10:12 AM
Steve260Z74's Avatar
Are you blowing fuses? If not, then you don't have a short. You may have a corroded connector or a connector that has been pulled loose/not making good contact. One other possibility is that a wire has been pulled loose.
Old Apr 8, 2013 | 04:20 PM
PredatorZ's Avatar
Combination Switch
The Instrument Combination switch on the steering column can be a source of lighting issues, sometimes a contact will become dirty or corroded. You will need to pull the steering wheel to remove it. Good luck tracking down this gremlin ! Not sure if its possible to clean the switch while its still in the car, use Deoxit to clean the contacts.
Old Apr 9, 2013 | 04:41 AM
reddzx's Avatar
XenonZ31 Headlamp Problems
Old Apr 11, 2013 | 10:49 AM
mr.chris's Avatar
That switch in the column makes perfect sense, ill be moving her inside in the next week or two to go over it again before summer. This headlight issue is on my list. Thanks a bunch guys ill let you know how it goes and I cant wait to get some pictures of my baby up on the site!
willey97
Aug 30, 2012 06:49 PM
280anniversary
Aug 20, 2005 03:04 PM
z32gizzle
15
Aug 7, 2005 02:00 AM
Denzil
Jul 2, 2005 07:08 PM
Al Dukes
Sep 2, 2003 05:24 PM
