Head lamps turning on by themselves
Old Mar 25, 2013 | 09:23 AM
illsahi's Avatar
I have a 84 300zx non turbo and I have been noticing whenever i park the car and turn it off. In 15 minutes or less the car's headlights turn on regardless of the fact the car is turned off and the headlight is switch is turned off. They turn on even without them being flipped up. If anyone knows what it may be please help me out because this scenario is killing my battery daily. Thank you
Old Mar 25, 2013 | 01:26 PM
rogerz's Avatar
Grumpy & Helpful
try pulling the fuse on the alarm system. it maybe trying to alarm
Old Mar 25, 2013 | 05:33 PM
Pete Westbay's Avatar
Maybe your headlight relay shorting ?
Old May 13, 2013 | 02:06 AM
RascalSwirl's Avatar
have you solved the problem? i had the same one, but i found when i left it turned off but clicked into high beam it didnt do it, i have a spare switch assembly here that im going to put in when i get a chance and see it that stops it
Old May 13, 2013 | 11:15 PM
SilvPath's Avatar
My '88 would do this all the time, I eventually just pulled the headlight fuses while I drove, and if I needed the lights I would just plug them back in. It seemed that they would turn on at the slightest bump. I replaced the switch assembly and I have't had any issues since.
Old May 14, 2013 | 10:38 AM
aZforZac's Avatar
I have the same problem. I also just flick my high beams on with the lights off. I was told to check my contacts.
Old May 17, 2013 | 05:47 PM
AZ-ZBum's Avatar
This.
Zdon
Apr 19, 2013 10:11 PM
thxone
Apr 7, 2008 02:47 PM
apollo
Jan 25, 2006 11:47 AM
ensmuns
Dec 30, 2005 12:46 PM
nightlights
Jun 19, 2003 11:31 AM
