Front Side Marker Lights not working??
Old Nov 15, 2014 | 03:08 PM
Neill Solomon's Avatar
It is a 1986 300zx NA with 70K miles on the original engine. Car is in amazing shape! All electrical works properly except that the front marker lights are completely unresponsive. I have replaced both bulbs but that was not the problem. It seems to coincidental that it is both of them. I have looked at the Haynes and the Service manual but for my skill level I can see anything that would affect only the side markers.
Do you know anything that would affect only them?
Side note, when I step on the brakes the voltage gauge goes down is that normal or should i be looking for a short?
Thanks,
Neille
Last edited by Neill Solomon; Nov 15, 2014 at 03:09 PM. Reason: Miss spelled and forgot a word
Old Nov 15, 2014 | 05:26 PM
zxguy1986's Avatar
Originally Posted by Neill Solomon
... except that the front marker lights are completely unresponsive
If the 'marker lights' are the yellow ones on the front quarter panel sides, their power supply needs to be traced back with a multimeter to the harness connections. First check all your fuses. Then check your FSM electrical diagrams EL-53-54, etc. (factory service manual - It's a freebie from http://www.xenonz31.com/reference.html) Start at the bulb sockets to see if they are powered. If not, then work backwards one connector at a time to see where the break is. Sorry but there's no shortcut for this. Weird that they both are out at the same time. Sounds like a dirty connector issue right at the point where their power feeds split - which means a harness connection just this side of the light stick on the steering column. It's all in your elec diagrams. Yeah, they're a pain to follow. (I use colored markers and trace the feeds on 11x17 printouts I got from my local copy shop. They stay with my manual for future reference.)
If your belts are tight, the voltage gauge is telling you that your battery/charging setup needs to be tested. Battery-selling places will do that for free. Your alternator needs to put out over 14v while charging the battery/running stuff. Check that. If it's less, your alt is dying. Replace it. Also your battery may be old and not holding its charge well. Check all your batt/alt cables and connections. Dump the crappy batt terminals and get good ones. If you get a new batt, get one with more cold crank amps than your Z requires. Z31s need very reliable electrical power every minute or stuff starts acting weird all over the place. It will make you crazy looking for problems elsewhere - when it's just your DC power supply
KingDatsun1
Feb 11, 2020 12:27 PM
rajgrewal
Jun 12, 2014 02:35 AM
luvturbo74
May 28, 2007 09:34 PM
scotts280z
Feb 7, 2004 06:29 AM
jake
Nov 7, 2002 04:22 AM
