foot step lights will not go out
87 300zx my foot step lights stay on and left door step light does not work, dome light on the roof works from both doors also the ajar light works from both doors. when i unplug the light control unit the right door works like it should but nothing works from left door when the unit is unplugged. this problem has me all confused any help would be appreciated thank you
Sounds like the door switch is hanging up. Try pushing it in when the door is open to see if the lights go out. If not, it may be corroded & needing replaced. Don't forget, I believe there is a delay switch on the system as well that slowly turns off the interior lights when entering & exiting also. My 85 has this.
jti30666
May 21, 2012 02:18 PM
Heat Rave R
Jul 8, 2006 12:46 AM
90NA300ZX
Sep 15, 2005 02:29 PM
