Faster
Old Dec 9, 2001 | 11:25 AM
Spot's Avatar
Re: Faster
Well you have a good start with the k&n. A performance computer can only do so much with stock injectors/fuel pump and air flow meter though. Since you've increased your intake, it wouldn't be a bad idea to open your exhaust up some too. Maybe go with a 2.5" exhaust system. You can also put a 240 or stanza throttle body on it at low expense. they are about 10mm larger than the stock Z one, and will bolt up directly if you get the right one. check <a target=x href=http://z31.com/modifications.shtml>here</a> for more info on modifications. Details on the throttle body can also be found either there or on one of the links on that page.
entropy31
Jan 10, 2010 08:44 PM
Jerkif
May 29, 2005 03:09 AM
Copper727
Dec 3, 2003 08:05 AM
CrazyLotusTT
Aug 19, 2002 09:18 AM
