drivers side headlight ghosting
Old Feb 23, 2017 | 02:39 PM
Numbnuts's Avatar
Ive been having an issue with the drivers side headlight coming on by itself thru the night. Switch is off, fog lamp switch is off. I jiggle the headlight (turn-signal) arm & it goes out. Is this a common problem? Just replace the switch? Ideas?
Old Feb 23, 2017 | 05:20 PM
Monkies's Avatar
Check out the video in this post. It is most likely your issue. The small contacts in the switch need some attention.
https://www.zdriver.com/forums/300zx...urn-off-41442/
Old Feb 23, 2017 | 09:21 PM
Numbnuts's Avatar
Thank you! It acted up again at work & tonight after I parked it. Its definitely the switch. I jiggled the turn signal (headlight) arm & it went off & on from the drivers side only. I threw it up into the high beam location & tried it again but it didn't repeat. Quick fix until I can pull it apart & clean it up. Thanks for the video!
zkyleax
Nov 23, 2011 03:00 PM
GARYZ240
Dec 12, 2006 09:01 PM
gram
Apr 6, 2004 01:46 PM
BASEBALL248
Jan 5, 2004 01:05 AM
kewlcat
Oct 26, 2001 09:36 AM
