Digital Dash Problems
Old Mar 4, 2002 | 06:22 AM
Spot's Avatar
Re: Digital Dash Problems
you can resolder the back of the circuitboard where the pins are connected to it. often the cracks in the solder are not visible unless u use a strong magnifying glass. I repair/resell these often and they're pretty simple to fix. I would guess that's the problem wiht the speedo and tripmeter problems. as for the fuel gauge it could be either the power supply or the amplifier on the circuitboard of the digital dash unit. I've only had limited success at repair of these and due to the time required to repair them, I've found it more economical to get one from the local junkyard.
for the cruise control - make sure the plastic buttons are in place on the brake and clutch pedal (only on the brake if yours is an automatic). Often these break and fall out. You can either order a new plastic button, or replace it with a small nut/bolt. if you do the nut/bolt then you should adjust the switch to allow for the extra thickness of the nut/bolt. also check the vacuum line going to the cruise control actuator located on the pass side strut tower.
Old Mar 4, 2002 | 11:30 AM
ZenArcher's Avatar
August? Where to/from...
ZenArcher
m tr4nch
Aug 10, 2014 08:49 AM
blockmaster
Nov 7, 2013 02:30 PM
Station
Jul 12, 2005 10:56 PM
marcello129
May 12, 2005 04:17 AM
nightlights
Jun 12, 2002 10:00 PM
