cruise control module
Old Aug 15, 2001 | 05:15 AM
Spot's Avatar
Re: cruise control module
the cruise control module is located in a cubbyhole behind the drivers side foot area.
if you remove the trim around the fusebox, you will see the fusebox and a relay strip with 5-6 relays in it. remove the hex nut holding the relay strip in and pull it out of the way. There is a rubber (sort of) piece covering a hole there in the side of the car - peel it away (along with the jute backing attached to it, and the ascd box is in that hole. If you need a replacement one, or more instructions and/or pictures, let me know and i'll get some out to ya.
laterz
spot
Old Aug 15, 2001 | 05:20 AM
Spot's Avatar
on second thought, it may be located a bit higher than the relay strip, you still shouldn't have to pull the dash though - just maybe remove some of the ductwork so you can get to the bolt that holds the box on there. Remember, it won't be obvious cause it's hidden behind a piece of rubber and insulation.
BobbySurfer
Dec 24, 2022 01:04 PM
anniversary_Z
Apr 10, 2011 08:16 PM
CWHammer
Nov 22, 2008 01:20 PM
User395
Feb 12, 2006 06:12 PM
AndrewB
Aug 11, 2004 05:07 PM
