ZDriver.com
-   300ZX (Z31) Forums (https://www.zdriver.com/forums/300zx-z31-forums-8/)
-   -   car antenna won’t go up (https://www.zdriver.com/forums/300zx-z31-forums-8/car-antenna-won%92t-go-up-43774/)
morgananfay Dec 20, 2023 04:29 PM
Hi,
I apologise for bugging everyone but I am currently trying to fix my 86 NA’s antenna. I took the exterior pieces apart today and the antenna slipped right out (disconnected?), but the motor appears to be working. When I press the antenna button the interior, it responds with a click but the antenna does not go up but it did retract when pulled out manually.
Is the motor broken? Or is it something else? I do not have much car repair experience so I apologise if this is a dumb question. I also only have the chilton manual so I know I should probably pick up something else to help. Thank you for reading!
Great White Zed Dec 21, 2023 09:43 AM
Originally Posted by morgananfay (Post 350233)
I apologise if this is a dumb question. I also only have the Chilton manual so I know I should probably pick up something else to help. Thank you for reading!
How far is up? How long is a piece of string? Now those are dumb quesions. Anyways...
1. Never underestimate the power of a Chilton or a Haynes manual.
https://cimg6.ibsrv.net/gimg/www.zdr...e2c32e1a72.jpg
2. In my case, the cable had broken. Once apart, you can get a new one should this be the case.
https://cimg6.ibsrv.net/gimg/www.zdr...7423decdc3.png
The replacement is usually comprised of a mast and cable. Available at the usual suspects. Repair instructions available here.
morgananfay Dec 21, 2023 06:22 PM
Thank you! I appreciate it. I’m still new to car things and trying to figure out a z31 as a first project is proving a bit tough haha! Thank you again!
