A/C HEATER PROBLEM
Old Oct 8, 2002 | 08:01 PM
Spot's Avatar
Re: A/C HEATER PROBLEM
if yours is a non-turbo, you should have 3 hoses. one is mounted onto a switch there on the vacuum servo above the carbon canister filter. that one should go to your heater **** valve (located at the rear of your engine on pass side, where the hoses go in thru the firewall to the heater core. one of the other 2 goes thru the firewall to a T just on the passenger side near the tranny tunnel. the 3rd goes to the rear of the intake manifold.
If your car is a turbo, there are 4 nipples, 3 like above and the 4th goes to the vacuum pump inside the front of the passenger fender behind the headlight.
Madison_Z
Feb 8, 2014 07:51 PM
77280ZX
Nov 20, 2012 03:34 PM
ZCHondaCRX91
Jun 14, 2011 10:10 PM
Charlie
13
Sep 30, 2005 10:21 AM
zsky
Sep 15, 2001 11:45 PM
