Best suspension parts to buy ?
So I've got an 86 na and I'm going to upgrade the suspension what should I go with tokico ?
do your bushings, ball joints and tie rod ends then worry about shocks. I've got tokico on mine and they are fine.
Yeah, I'm with rogerz on that. Everything that either moves with the wheel or keeps it in line is part of your suspension system. Shocks are only part of that. Your '86 had an original suspension and steering performance that would knock your socks off today - perfect balance and perfect straight-line tracking on any road condition at any speed.
All those parts are worn down or out on your Z - no doubt about it. The closer you can get it back to that original condition, the better. It will blow your mind when you finally have it right. It's what your Z was born with. :slywink: When you think all your components are installed right and ready to perform, use a serious pro tire shop to check/adjust your alignment, front and rear. You may find more work needed. Getting it perfect is really worth the time and bucks tho. Magic on the road! :054: |
Was there any thing better /lighter for the rear control arms 4130 like , racing ?
:040: |
