Anyone ever try a Sankei oil pressure sender?
Old Sep 24, 2014 | 08:30 PM
Zuphoria's Avatar
Found some on ebay for $30. Very tempted but wanted to know if anyone here has tried one.
http://www.ebay.com/itm/New-Sankei-Oil-Pressure-Switch-25070-21P00-/361050595272?pt=Motors_Car_Truck_Parts_Accessories&hash=item54104adfc8&vxp=mtr
Attached Thumbnails Anyone ever try a Sankei oil pressure sender?-sankei_oil_pressure_switch.jpg
Old Sep 24, 2014 | 08:32 PM
Zuphoria's Avatar
I mean for 30$ its worth stoping the oil drip coming from my sender unit!!
Old Sep 28, 2014 | 10:05 AM
Zuphoria's Avatar
ill just buy one and try it. ill report back.
Old Sep 28, 2014 | 01:12 PM
zxguy1986's Avatar
I would try it. I never had any luck with the OEM senders. They have always read low so you can't trust 'em. Let us know if the Sankei fits and works right!
Old Sep 28, 2014 | 07:25 PM
Zuphoria's Avatar
It will be here next week.
Old Oct 2, 2014 | 09:08 AM
iwithnell's Avatar
Let us know how it works. I've got an 88 NA that is still pretty much stock and needs so much work I don't know where to start lol
Old Oct 2, 2014 | 10:51 PM
zxguy1986's Avatar
iwithnell, sounds good. A Z31 with no work to do is boring! So, include our Z31 guys in your work and post your issues here as you find them. Start a new thread or two and be sure to include photos. They bring us right to your Z and make it easier to help.
Your Z will return the favors for all the work you put into it. Z31s are like magic.
Old Oct 5, 2014 | 01:21 PM
cbernone's Avatar
Originally Posted by zxguy1986
iwithnell, sounds good. A Z31 with no work to do is boring! So, include our Z31 guys in your work and post your issues here as you find them. Start a new thread or two and be sure to include photos. They bring us right to youhowr Z and make it easier to help.
how you get the old one out?
How you get the old one out?
Old Oct 9, 2014 | 09:02 AM
Zuphoria's Avatar
With an open end wrench. or just grab it with your hand and turn CCW. Sorry guys i got the Sankei sender in but havent installed it yet. doing the timing belt and hoses now. Ill update when i get that done.
Old Oct 9, 2014 | 10:10 PM
zxguy1986's Avatar
Holding my breath, Zuph... waiting for the results
You're right about removing the old one. I did it by hand, no wrench. Was surprised how easy it was to turn. (CCW)
Old Oct 10, 2014 | 06:46 AM
Zuphoria's Avatar
here it is
Heres some pics... havent installed it but it looks like good quality. Really....looks oem besides the yellow connector color
Attached Thumbnails Anyone ever try a Sankei oil pressure sender?-oil1.jpeg   Anyone ever try a Sankei oil pressure sender?-oil2.jpeg   Anyone ever try a Sankei oil pressure sender?-oil3.jpeg
Old Oct 10, 2014 | 02:35 PM
zxguy1986's Avatar
Yep. Pretty as a peach. Let us know what it reads on the gauge when you're on the highway at, say, 3000 rpm... That will be info worth your cost and labor...
Old Feb 9, 2015 | 07:13 PM
Zuphoria's Avatar
Put it on finaly!!
I installed the Sankei sender, everything went ok. plug fit right on and even the rubber boot cliped into place! The pic shows the pressure with the engine cold on startup running for about 1 min. After i drive around for about 30 mins the needle falls below the 30psi notch about halfway from 0-30. what u guys think?
Attached Thumbnails Anyone ever try a Sankei oil pressure sender?-sankei-oil-sender.jpg
Old Feb 10, 2015 | 06:37 PM
ken99's Avatar
Look in the FSM
Factory specs for oil pressure at specific RPMs are in the FSM. I would also be concerned that your temp gauge is still pegged on the low end of the scale after running the engine for 30 minutes.
Old Feb 11, 2015 | 06:08 AM
Zuphoria's Avatar
ya, ill check the fsm to match some numbers. And ya the oil temp gauge is low because im using a sender unit from an 81 280zx turbo i found in the junkyard. screws in the oil pan correctly, but there is definitely a ohm resistance difference.
ryn004
Aug 8, 2014 03:05 PM
Z92AL
Mar 1, 2013 10:09 PM
wgc_3
Jan 1, 2007 07:29 AM
OlderThanMe
Sep 1, 2004 04:08 PM
bbigaal1
Oct 6, 2002 01:25 PM
