Alternator Replacement 1986 Z na
Old Aug 26, 2003 | 11:25 AM
Spot's Avatar
Re: Alternator Replacement 1986 Z na
It's not very difficult. It can be done without jacking up the car, but raising the car certainly makes it easier. You don't have to get it 2' off the ground, just enough to slide under to access the lower mounting bolts. They can be accessed from the top, but like I said, it's easier from the bottom.
Hand tools will be just fine, I never break out the air tools for an alternator swap. You will need an extension though, to get to the upper bolt on the rear of the alternator - tha'ts the hardest part of the whole job. I'd say 2.5 hrs tops from the time you step into the driveway to the time you crank it up afterward.
Shouldn't take any longer than that.
Hint: remove the subharness along with the alternator, it detaches from the main harness via 2 plugs. Follow from the alternator to find them. Then swap the harness to the new one before you install it. This way you can check the connections and wires for any bare spots and wear.
ABSOLUTELY, POSITIVELY make sure that whomever you buy the alternator from tests it BEFORE you even pay before it. Remanufactured units are notorious for being bad right from the store shelf. O'Reilly's, Autozone, Carquest and others have capabilities to test it before you leave the store with it. This will potentially save you hours (sometimes days if they've got no more in stock) of downtime, and labor on your part. Sucks to install one, only to find out that it's no better then the one you just yanked out.
I can't recommend a brand or cost of one. I usually have a spare on the shelf from a functioning car that i parted out, so I've never had to buy one.
Daniel Coffman
Apr 14, 2013 06:36 PM
Niku-Sama
Jul 14, 2008 04:18 PM
koukiAE86
Jan 24, 2008 08:21 AM
Goofyz
Jul 10, 2007 10:26 PM
jtodafullest25
16
Sep 27, 2006 06:04 PM
