all warning lights on the instrument panel light up and stay on.
Old Jul 1, 2004 | 09:43 PM
FireDhusky's Avatar
hihi
another wierd thing on my 87 z auto
all warning lihts come up at the same time on the instruments panel and they stay on
aslo noticed a low voltage...
i unpluged the 2 wire conector from the alternator (cos i suspect someting is funky with it) and the warning lights operate normal.
so no charge and warning lights.... bad alternator ?
thankies for your wise advice.
FIre D Husky
Old Jul 2, 2004 | 09:14 AM
91zxtt's Avatar
Yes, bad alternator. I had the same problem on the Z31 I had 5 years ago.
Old Jul 13, 2004 | 01:15 PM
FireDhusky's Avatar
Hi , thanks i m in the process of changing the alternator but im lost now becouse i cant take it out ( i unvolted it all tho i find no place to slide it out)
thanks
FDH
Old Jul 14, 2004 | 09:35 AM
91zxtt's Avatar
You have a bolt located at the top of the alternator in the fron and the rear. The adjustment bolt is on the bottom at the fron of the alternator. All of them have to come all the way out. You also need to disconnect the plug and the ground from the back. You pull it out from underneath the car. You need to take the belly pan off. It should just about fall out.
Old Jul 19, 2004 | 11:34 AM
FireDhusky's Avatar
Thanks for your answer : )
I had to take the stabilizer (swaybar) down to have it go out. now all works beautifully !
Thanks !
worder
Jun 18, 2013 06:23 PM
excel8927
Jan 19, 2011 02:29 PM
Todd1545
Jul 22, 2006 05:50 PM
surfacing121
Feb 20, 2004 06:54 AM
980MAK
Sep 8, 2001 02:28 PM
