AC Options When Repairs Needed
Old May 15, 2002 | 08:36 AM
Spot's Avatar
Re: AC Options When Repairs Needed
Hey Joni!
I've heard R-134 isn't as cold as R-12. I still use (at great expense) R-12 since I consider it a "known good thing".
laterz
spot
Old May 15, 2002 | 11:00 AM
Spot's Avatar
From what I understnad.... R-134 runs best at a higher pressure, so your leaks will only leak faster and/or get worse. I would suggest next time it's all leaked out, to have a vacuum pulled on the car, diagnose how bad the leaks really are, and then pressurizing the system with air and locating the leaks. You may find out that it's merely o-rings that you need. Then decide whether you want to replace the leaking part(s), and go with a R-134 or R-12. I spoke to Kin about it (you remember him from the meetings right?), and he advised sticking with R-12. One of the reasons R-134A doesn't cool as much as R-12 is that it requires higher compression. Our compressors were designed to compress R-12 (which requires less).
Personally I've heard too many stories about R-134 to use it.
the.momo.lives
Jul 30, 2010 04:06 PM
mooredb
Jun 20, 2010 12:33 PM
RedZCar
Mar 9, 2007 09:32 PM
SpeedyZ
Jul 10, 2006 07:54 AM
NISMO92300ZX
Nov 3, 2002 08:43 PM
