ZDriver.com
-   300ZX (Z31) Forums (https://www.zdriver.com/forums/300zx-z31-forums-8/)
-   -   AC (https://www.zdriver.com/forums/300zx-z31-forums-8/ac-298/)
Ghostz Apr 28, 2001 05:18 AM
AC
Hey All,
I seem to be having a small problem with the AC on my car. It (the car) is an 86 zx w/auto climate control. My problem is that whenever the AC is running and I push the tach up above 2600 RPM, all I get is warm air instead of cool. Any suggestions? My local Nissan shop is about as worthless as they come, I had to take the car elsewhere to get the belts changed, they'd never done one before.
Thanks.
Ghost
Skaitan Apr 28, 2001 06:02 PM
Re: AC
have you checked all your vacuum hoses yet? I had a similar problem with my 85 turbo, and all my hoses were disintegrating, now my temp control works much better since I replaced them...
skaitan
Ghostz Apr 28, 2001 06:08 PM
Re: AC
Actually had ALL of them replaced when I had a heater core blow. Still didn't seem to fix the problem.
Thanks though,
Ghost
ZenArcher Apr 28, 2001 11:40 PM
Re: AC
Ghostz,use the search feature at z31.com,that's a common problem.Use the search before you post there unless you're thick-skinned because there are some asses there that would rather give a half-page reply telling you to search the archives than to simply answer your question.But there are some that would reply and maybe give you a solution.
ZenArcher
AZ-ZBum Apr 29, 2001 10:02 PM
Re: AC
How's the freon level? When my '84 was doing that, I had the freon recharged, and it worked great. It still does 4 years later.
...and from the ashes shall rise a new hope. And it shall be known as "Z". And it will be good.
Ghostz Apr 30, 2001 09:28 PM
Re: AC
Zen,
I really am not that thick, at least not to my knowledge. I haven't been able to pull z31 up for almost a month now, my server says it doesn't exist, @#$%^&&**^&# thing. Anyways, I hear that there are soleniods somewhere in there that are attached to the system that could be the culprit. Any suggestions? Oh, Nissan (not that they have been all that helpful in the past) says that the freon level is fine( thanx for the suggestion AZ) and that nothing is wrong with the car at all. $#!@#$ mechanics. Anyways, thanx for any advise,
later
Ghost
ZenArcher May 1, 2001 03:55 PM
Re: AC
I don't know if Z's have them but some car's have a low switch or something like that.Hell,a/c trouble is just a bitch any way you look at it.My a/c on my old 280 was all screwy.Sometimes it worked sometimes not.I tore into it 3 times and couldn't find anything wrong.
ZenArcher
ZenArcher May 1, 2001 04:01 PM
Re: AC
I don't know if Z's have them but some car's have a low switch or something like that.Hell,a/c trouble is just a bitch any way you look at it.My a/c on my old 280 was all screwy.Sometimes it worked sometimes not.I tore into it 3 times and couldn't find anything wrong.Never said you were thick,just letting you know in case you didn't already.They sometimes take up half the page going on about questions that have been asked already.And then take up the other half w/ some really stupid [censored] like who's got the best engine bay color scheme,lol.
ZenArcher
Ghostz May 2, 2001 11:14 AM
Re: AC
Wasn't really offended at all. I have seen the posts over there and you are right. I'll just keep taking it apart until I find the problem. Thanks
Ghost
