87 300zx turbo NEED ADAPTRONIC BASEMAP!!
hi all! So I have an 87 300zx turbo with an adaptronics 440 ecu, agp gt40, 1000cc injectors, bigger fuel pump, tial 38mm wastegate, fuel pressure regulator, 2 1/2 intercooler piping with a mishimoto intercooler and radiator. So the car was running pretty good a little while ago and something happened to the trigger settings and now it just doesn't want to start and when it does it runs sooooo rough! I just did a timing belt job and everything was all lined up perfect and it still runs the same as before. Some please help!!
Originally Posted by Brian Deane
(Post 346174)
if it doesnt /cant turn down the milsec on the injection it will run rich and foul the irridium type spark plugs if it cranks more than 7 sec and not firing ,best to unplug the injectors |
Originally Posted by 86tcoupe
(Post 346175)
how rich is it running ?
Yes live data is what you need , but pre obd or OBD1, it is tough, even at a dealer
you have a aftermarket FI ECU ? it was working good but not now? The platinum style plugs foul and must replace , sure the CC isnt plugged ? |
