86 300ZX
Old Oct 5, 2002 | 05:06 AM
Spot's Avatar
Re: 86 300ZX
Check your local junkyards. if yours is a 2-seater then any otehr 2-seater's parts will fit yours fine. The only exception is the door panels. You will have to use 86 or newer door panels as the inside handle is in a different position. You can use 84/5 ones if you also get the rods connecting the handle to the inner door mechanisims - your '86 door will have the slot for relocating the handle cut in it already, but the connecting rods are different. If your car is a 2-seater, the dash and lower trim panels, and armrests (on the door) are the only thing from a 2+2 that will interchange with yours, everything else is sized differently. It's vice versa if yours is a 2+2.
nismo619
Jun 11, 2012 07:56 PM
