#5 Cyl Eng Miss 86 Non turbo
Old Jun 6, 2002 | 06:51 AM
Spot's Avatar
Re: #5 Cyl Eng Miss 86 Non turbo
one of those 3 mechanics should have performed a leakdown test on it. that will tell you where you're losing compression. 160 seems low to me. My '85na's lowest cylinder had 185 psi, and the highest of 200. (this doesnt' include the cylinder with the hole in the piston or the one with the lump of steel stuck in the intake valve seat - both of those had 0 compression).
A leakdown test will tell you if it's leaking thru the intake valve, exhaust valve, piston rings or whether there's a leak in the head gasket between cylinders.
abcsgarage
Sep 8, 2011 10:25 PM
Twitch
Aug 26, 2010 11:56 AM
jaredjmoore89
47
Jan 5, 2009 04:16 PM
Riz Z Speed
Feb 11, 2004 10:32 PM
ZenArcher
Apr 20, 2002 02:10 AM
