1989 300ZX Turbo Custom Exhaust
Old May 28, 2014 | 10:56 PM
N300zx89's Avatar
Hello all,
I have a 1989 300ZX turbo and i want to do a custom exhaust on it. Im going to leave stock headers however after that, I am doing a High Flow Cat, then straight piped back to a muffler. Now for the muffler, What do you guys think would sound better? 3" Pipes 3" exhaust outlet? 3" pipes 3.5" outlet? or bigger?
Any help would be much appreciated!
Old May 29, 2014 | 12:24 PM
Zuphoria's Avatar
3 inch all the way out.
Old May 29, 2014 | 07:16 PM
N300zx89's Avatar
So that would sounds the best then? I was this to be a loud deep tone
Old May 29, 2014 | 08:36 PM
86tcoupe's Avatar
I will tell you my set up on my 86 turbo It was completely stock and would roast the left side inner tire . I removed the muffler and went with a straight thru cherry bomb type and a larger Cat , it fixed the problem . it has noticeably more power 2-4k mostly . get ready for a drop in mPG though 3-5 IMO
the frt pipe is 3" already with the rear 2 1/2 or 3/8, you won't gain much for the $$
I did the flared tip which at 60mph + gives a bit lower pressure ( the aircraft cowl effect)
but quicker flow can cause more heat in the system and damage parts quicker in the engine side especially if it cannot richen up enough
on a carburated engine, freeing up the exhaust requires a rejetting or richer mixture
JSM
Jul 20, 2013 09:12 AM
uobig
Oct 4, 2003 07:29 PM
uobig
Sep 21, 2003 06:07 PM
uobig
May 26, 2003 01:50 AM
uobig
FS: 300ZX (90-96)
May 26, 2003 01:48 AM
