1985 300ZX - Headlight Ghost
Old Jun 7, 2002 | 08:11 PM
Spot's Avatar
Re: 1985 300ZX - Headlight Ghost
it could be the switch on the column. those are a common problem on these cars. You can remove and clean it - that may help, or find a good one at a junkyard or buy a new one.
there is a diagram in the haynes manual telling you at which positions you should have continuity. use that to test the switch.
Old Jun 7, 2002 | 09:05 PM
Spot's Avatar
The switch i'm talking bout is the one on the column. pull steering wheel and 2 tiny phillips hold it into the center stalk.
look at the back of it and you'll see a thin rectangular yellowish piece. pry that off (carefully) and you'll see where the contacts are. try using a business card to clean with as sandpaper is too harsh.
hope this helps
spot
WildmaN
Feb 26, 2007 10:58 AM
VegasEdge
Sep 6, 2006 03:56 PM
jovel_t
Jun 21, 2005 01:54 AM
shane_90TT
Aug 18, 2003 11:54 AM
lynz
Feb 2, 2002 10:55 PM
