ZDriver.com
-   300ZX (Z31) Brakes, Wheels, Suspension and Chassis (https://www.zdriver.com/forums/300zx-z31-brakes-wheels-suspension-chassis-76/)
-   -   Wipers AND washer doesn't work... STUMPED! (https://www.zdriver.com/forums/300zx-z31-brakes-wheels-suspension-chassis-76/wipers-washer-doesnt-work-stumped-39476/)
todd5854 Apr 6, 2014 12:09 AM
I have an 85 2+2 n/a with an analog dash. 276,000 miles.. When I first got the car, the wipers worked most of the time. Yeah that's right, most of the time. Then the intermittent wipers stopped working. I guess my TCU went bad? Oh well. Then eventually they all stopped working. I tried to send 12v directly to the motor and nothing. I guess I need a new wiper motor, but the washer still does not work.
Other symptoms-
the fuse melted.
rear washer and wiper work fine.
replaced fuse, no change.
sometimes dash illumination lights flicker at a constant rate. When I open the door and my faulty door check clicks, it goes away. (The door check is the thing that prevents the door from opening too far)
I have no idea where to start on this one.
zxguy1986 Apr 6, 2014 05:27 AM
Your FSM covers this system on EL-119 and following. I don't see a troubleshooting section, though.
I would get out my multi-meter and check that there is power to the fuse and each wiper motor and washer pump when the stick switch on the steering column is in its various 'on' positions. Since your rear wiper & washer work fine, you can use them as the standard for checking the front units. If power is getting to the front units, I would replace any motor and pump that isn't working when it's getting power. As you trace the wiring to this stuff, check any connector you come across, disconnect it and clean it with a good electronics cleaner - and reconnect it.
If a motor or pump unit is not getting power and the fuse is good, I would suspect that the wiper control stick on the steering column is worn out (dirty?) and replace (clean?) that. I don't know if the stick is still available new like the lights/directionals control stick is ($120?). But recyclers should have them - as well as the wiper motors and washer pumps. Start looking at car-part.com and sort results by distance from your zip. Maybe you can drive there and pick stuff up. (I picked up a whole steering column with steering wheel and both control sticks here, $60 - just in case...)
Temporarily, you can try Rain-X or one of those products that claim you can drive without wipers in the rain. That stuff makes me nervous. :120: Gotta get those wipers working. :002:
FlyingT Apr 6, 2014 10:12 AM
ZXguy is right, check with a volt meter to see if power is getting to the wiper motor and washer. That will tell you if the motors on both are toast or not. Not unusual to have a washer motor go bad after 30 years.
This guy probably has anything you need.
300zx Parts For You webpage
todd5854 Apr 6, 2014 05:50 PM
Today I noticed that when I hit or smack my drivers door kick panel, the instrument lights act normal again. What is in the kick panel besides the fuse box? I had a 240sx, and a box was located there which controlled interior lighting. Maybe mine is starting to go bad? I can solder fairly well, maybe I can just fix it.
It would make sense that the wipers would be controlled from the box, or power that came from that box. Only problem is, none of this explains this:
This is my wiper fuse
https://farm8.staticflickr.com/7172/...e7f6db708b.jpg
zxguy1986 Apr 6, 2014 07:58 PM
My guess is somebody has screwed around with your fuse box since 1985. Sounds to me like you have junk floating around inside the box and various circuits are being shorted or grounded out. Or you have poor connections between fuses and socket grips, all caused by somebody screwing around in there...
I would light the area up bright so you can see, ignition off, pull out every fuse, vacuum the inside of the box with high power suction and long hair brushes, then check the re-insertion of every fuse, one at a time by hand, checking that each fit is clean and tight. If the copper contacts are corroded/oxidized, you should clean them as best you can. Fine sanding... emory boards? copper cleaner on Q-tips? Figure out a way.
If a fuse socket looks bent to you, try to bend it back into correct shape/position with a fine needle nose pliers, so it's the same shape as the others and grips the fuse tight. When that is done, begin the power check up I described above. You need wipers first. The rest can follow. :unibrow:
The fuse in the photo doesn't look blown to me. Looks broken. If it's melted, I would still start with the above. Weird stuff in your fuse box. My guess...
Remember to report back when you get 'em working again so we know what you did. Thanks
todd5854 Apr 9, 2014 10:42 AM
Update, it is now fixed.
Leaving work last night, I shut my door, and locked the door by sliding the drivers side door to LOCK. I looked over at the passenger side, It locked, unlocked, locked, unlocked again, and then finally locked. My dash lights were flashing again, so I gave the drivers side kick panel a good smack, and the dash lights returned to normal. AND... the wipers came on! AND...the washer worked!
Now, how to fix this? Sounds like there is a loose wire, or a bad ground somewhere. Roger told me to sand down my ground in the engine bay, as it's the most important one for the electronics.
By the way, since last night, the wipers and washer have worked since.
Darklink14 May 23, 2024 08:57 AM
Reviving for anyone facing this issue. There is a tiny printed circuit board that is in the front drivers side fender behind the wiper fluid reservoir. This only affects the intermittent mode and the spray/wash circuit I believe. Take it out, inspect connections and re-solder all the points on the pcb. Just reheating them to melting point should re-establish a connection and remove impurities.
Nitro Jun 27, 2024 11:37 PM
Wow, brought back the topic 10 years after and just as I also stuck with this problem and looking for the cure! :) Thanks, will look there also.
But it seems strange that I don't hear any relays working when turning wipers on or using a washer. I think there's no voltage or ground on some relays - gonna check one by one by the circuit diagram.
P.S.: web forums will live! :)
Mrlhand Jun 28, 2024 06:28 AM
Fuses Loose.
Had same problem with hazard lights. I took out the fuse and cleaned up fuse. Took small screw driver and pinched the two fuse panel clips together to make fuse fit tightly. Re-inserted fuse and no problem since.
Larry
Nitro Jun 30, 2024 11:32 PM
Small question, maybe someone done that. Can I remove the TCU (time control unit) from the system? I won't be able to control the intermittent mode wiper work interval, but at least it will work just somehow intermittent. :) I think the TCU is broken, I already connected the dash lights around it. I don't want to change it at the moment, as I will have to look, order and wait for it for some time and will have to disassemble half of the car to change it. :)
Correct me, if I'm wrong. I see only one wire, coming from TCU to intermittent adapter, pink-black. I can suppose, that if we will emulate there some voltage or resistance there, it will be the interval setting.
https://cimg6.ibsrv.net/gimg/www.zdr...16dd917f91.jpg
