Question about rear suspension?
Hi,
I am new to the site and just purchased an 86 300zx non-turbo. This is my first import and was wondering my rear tire's toe-out at the bottom where the tire meets the road. What can I do to eliminate this problem before I put new rims and tire on the vehicle? Also do the make a kit to keep this problem from returning? The vehicle's suspension is stock and unmolested. I am use to full / tubed axle so this is new to me. Thank you for the time and advise. |
Hey welcome to the site. but I think u may have accidentally posted ur question on the wrong page. Ur car is a Z31, this section of the site is for Z32s. But to answer you question anyway, you can try to find some rear adjustable tie rods. I dont think Stillen makes any for ur car. But u could look there. Sry, i know i m not being much help. Good luck though. Try the Z31 page..you'll get better help there.
Moved to 300ZX (Z31) Brakes, Wheels, Suspension and Chassis.
In response to your question, the Z31 was designed with a negative camber in the rear wheels. In other words, the rear wheels essentially swing outward from the bottom. With age, that is -- worn coil springs and possibly worn shocks -- the negative camber worsens. The result is that you will wear out your rear tires prematurely. Trust us -- many on this site can attest to it. Do a web search for a rear camber adjustment kit. You should be able to find one although they are outrageously priced for the simplicity of the part! Check out z31.com for more info., and I also think that azbum.com has instructions for doing your own camber adjustment. Hope this helps, and good luck.
Mark |
