Little help on wheel studs
Old Mar 19, 2010 | 06:56 PM
260zturbo's Avatar
Stupid Hurricanes...
ok, i need longer wheel studs so i ordered Nismo wheel studs. I had taken a stock wheel stud out of my z31 hub and found that the hub hole needs to be bored out.
a difference of 1.32 mm (nismo - stock) The question is would be ok to bore out the existing holes to fit these studs? I dont see why this would be a big problem. Bore them out just enough so these sit just as factory. The hub bore is around 12.35. So maybe just bore out 13.7 mm. so that it has to snug in like a stock stud. taking out about 1.35mm It dont sound like much granted i have to do this 20 times but im just seeing whats your insight.
Old Mar 20, 2010 | 11:19 AM
you couldn't find an exact match stud just in a longer length? seems like alot of work just for wheel studs... however if you got the math worked out i don't see the harm. as long as the bore is straight.
Old Mar 20, 2010 | 12:45 PM
260zturbo's Avatar
lol yea does seem like alot of work for just studs but i guess i need to find different...found some that are 13mm diameter
Old Mar 20, 2010 | 01:02 PM
also, your user name is wrong. you do not own that car anymore. please fix it :P mods/admins?
Old Mar 20, 2010 | 05:10 PM
KasbeKZ's Avatar
Pr0n Addict
admins only *** i've been through that!
260zturbo
Nov 25, 2009 06:52 PM
MistaZ31Turbo
Jun 18, 2009 01:10 PM
CWHammer
Oct 19, 2004 08:17 AM
Spudz
Oct 3, 2003 10:13 AM
zpeedracer25
Mar 19, 2003 02:43 PM
