High pitched squeal
Old Nov 7, 2009 | 09:09 AM
ZCarz's Avatar
High pitched squeal
My 85 Z has recently gotten a high pitched squeal when I put it in reverse. It doesn't make the sound when in other gears. Is this the break pads? It seems to be coming from the wheel area. The sound stops when I apply the brakes.
Old Nov 21, 2009 | 08:44 PM
WiZZard's Avatar
Sounds like the break pads are getting low. The pads will drag a small metal plate against the rotors in reverse gear when they are close to worn out. Time for a break job.
Old Nov 22, 2009 | 07:07 PM
Z Car Barbie's Avatar
User Friendly
In reverse? It's usually most of the time or intermittently when the brakes are not applied. ZCarz, I don't know if you have an AT or MT transmission, but when you park your car, do you use the parking (emergency) brake?
chefbigjon
350Z Brakes, Wheels, Suspension and Chassis
May 2, 2014 06:18 AM
PredatorZ
Oct 21, 2011 11:26 AM
vitaminZ
Mar 31, 2010 01:38 PM
plainwhiteZ
Oct 19, 2007 07:06 PM
WallZ
Nov 28, 2003 06:33 PM
