clear headlight covers
Old Jul 19, 2008 | 04:09 PM
Sweets's Avatar
Usedta be Justin260z
I want to buy the early z31 headlight covers that MSA carries. Only problem is I dont know what they look like up close. Do they have big ugly brackets / do I have to drill holes in the bumper to install them? I searched and found no pics. Does anyone have these on their z31 who is willing to share a pic or two?
Old Jul 19, 2008 | 05:21 PM
johnZboy's Avatar
Distinquished Guest
History....
Yes, there are brackets. No they are not big, and, no you don't need to drill. Two sided tape attaches the brackets to the bumper cover.
At 85mph, I had to go back and find one of mine...
Sorry, you'll have to click the link. I can't believe the [IMG] code is Off in the "Appearance" forum.
Old Jul 20, 2008 | 04:15 PM
Sweets's Avatar
Sweet, thanks. Is there is a black rubber seal around the bottom and sides? Kinda looks like it.
Old Jul 21, 2008 | 08:13 PM
inqui-Z-tor's Avatar
JZB (hey John) is correct .. you don't need to drill .. BUT .. depending on how hot it gets where you live .. drilling may be your best option. It's been known that the dbl sided tape can weaken due to heat (like hot days in CA and AZ). This means the plastic covers can (and have) flown off while the car is in motion.
Note, as I recall .. the dbl sided tape holds the brackets in place. Velcro is used to hold the plastic lense onto the bracket. This facilitates cleaning between the cover and the headlamp .. AND makes it easier to change headlamp/foglamp (for 84-86 models) as the case may be ..
Old Jul 22, 2008 | 05:31 AM
johnZboy's Avatar
Distinquished Guest
No. It's just some black, vinyl, "C" channel edging. Honestly, this was so long ago I can't remember if it came with the kit, or, was just some left-overs from another project that I decided to use for an added touch.
inqui-Z-tor is correct. The two sided tape keeps you from drilling holes, but, if you drive at highway speeds in hot climates, they will take flight.
Sixer
May 6, 2010 02:07 AM
slalomskz
Jan 23, 2009 05:30 PM
Brandar77
Sep 1, 2003 08:26 AM
Robert Garfias
Jun 3, 2003 11:29 AM
stickben
Apr 4, 2001 08:12 AM
