White smoke
Old Sep 3, 2009 | 05:40 PM
ZXT83's Avatar
White smoke
My z has been sitting for the last few weeks. Now when i start it up i get white smoke billowing from the exhaust. Is this a sign of a blown head gasket? I dont think it is a blown head gasket seeing is how i have driven the car in almost a month. Any advice?
Old Sep 3, 2009 | 05:47 PM
What's the exhaust smell like? Coolant? Fuel? Oil?
Have you checked all the sensor connections? AFM? TPS? CHTS?
Have you pulled the spark plugs to see if they are wet w/ fuel or coolant?
Old Sep 3, 2009 | 06:25 PM
Niku-Sama's Avatar
eff good grammar
dont know why your bothering with all those questions, white smoke is a dead ringer for coolant entering the combustion chamber
Old Sep 3, 2009 | 06:55 PM
^^^ Or running hog rich as was the apparent issue on this guy's "white smoke": https://www.zdriver.com/forums/showt...ighlight=white
Old Sep 3, 2009 | 07:27 PM
or the seals are failing on his turbo....
Old Sep 4, 2009 | 07:53 AM
ZXT83's Avatar
the smoke doesnt smell like coolant
Old Sep 4, 2009 | 07:55 AM
ZXT83's Avatar
i read the other thread nismo posted on here. Ill start from there and begin diagnosing my problem
Old Sep 7, 2009 | 06:45 AM
Turboz's Avatar
If you use synthetic oil it will smoke white.
Does it stop after it idles a while if so it might be the turbo.
Old Sep 8, 2009 | 07:30 AM
ZXT83's Avatar
it does stop after running long enough, i pulled my plugs and found no coolant on them. The smoke also smells like oil
Old Sep 10, 2009 | 12:33 AM
lifegrddude's Avatar
Externally Wastegated
Is your zxt a/t or m/t? If it's a/t, check the modulator valve by the downpipe and replace it. It will make your Z smoke once it starts to go bad.
Old Sep 10, 2009 | 01:09 PM
ZXT83's Avatar
a/t, thanks ill check that out
bholm6
Apr 17, 2012 09:18 PM
tomas1329
Nov 9, 2009 12:37 AM
marc z
Apr 15, 2009 08:52 PM
c-murder
Oct 29, 2006 05:24 PM
Togish1
Sep 17, 2002 08:34 AM
