warning lights stay on when car is off???
Old Jan 6, 2011 | 02:59 PM
excel8927's Avatar
Im driving my car around and its running great, but when I turn the car off and take the key out the warning lights come on, brake, fuel, door etc. I took out the ignition switch blew it out with compressed air worked for a couple days but now its doing it again. Does anyone know what this might be, and ideas or thoughts? thanks guys
Old Jan 6, 2011 | 04:47 PM
mrprofile's Avatar
well, check the fuses, spray the ignition with WD40 check everything its warning about, gas, closed doors, lights off, etc... ignitions aren't horribly expensive, i bought an oem one for like 70 bucks, just make sure the keys are the same direction so you can re key the locks to be the same
Old Jan 6, 2011 | 05:05 PM
excel8927's Avatar
normally all these lights should go off when you take the key out. Its already killed one battery. its just acting like the key is in the on position. and i have half a tank of gas, they stay on when the door is closed and all interior lights turn off as they are supposed to. at this point i think ill just have to try a new ignition switch. I just wanted to know if there was another problem I havnt thought of yet. thanks for the help though
Old Jan 6, 2011 | 06:44 PM
Not to jack the thread or anything. But where did you get an OEM ignition for that cheap? Post a link if you could. Thanks.
Old Jan 6, 2011 | 07:18 PM
mrprofile's Avatar
ah ok, you might want to try rebuilding the ignition or something, i think there moderately easy to take apart, clean and put back together, you might find yourself wondering where a spare spring went after putting it back together though lol, as i have done on many of my airsoft guns
Old Jan 6, 2011 | 07:23 PM
mrprofile's Avatar
after double checking my "records" it turned about to be roughly double what i said lol, around $130 (with the unused security bolts that snap off), must have been something else I bought, like seat belts or something, anyway I got the ignition off a guy on Ebay, who I think is still selling Z car stuff
Old Jan 6, 2011 | 08:50 PM
excel8927's Avatar
yeah the ignition switch from my local oreilly is like $140 or something. ive taken it apart and cleaned it out already but still same problem. im gonna try a new ignition switch and see how that works ill check back and let u guys know how it works in case anybody else has the same problem in the future
Old Jan 7, 2011 | 03:20 PM
excel8927's Avatar
I went to a junkyard to look for a new ignition switch and i found it but the problem is that the mounting bracket to the steering column had two of the screws had round heads, completely round, not stripped but just completely round. I've never seen anything like that before, on mine there are two phillips and two flatheads. I've seen anti-theft torqs screws before but this has me baffled. And they were screws not rivets or anything. Anybody have any thoughts, or suggestions, or seen something like this before?
Old Jan 7, 2011 | 07:04 PM
mrprofile's Avatar
Yes, and i have good news so long as you have a dremel, you'll be fine, you could also use a file if you have a lot of patients.
They are security bolts, the bolts would start with a male square bolt, they would screw them in and then the square part would be snapped off, if you want to remove it you have to use the dremel to make it a slotted head, and then just unscrew it.
Or if you can find it, the button located somewhere on the car that activates the explosive bolts to release them, nobody has been able to find it though.
Old Jan 8, 2011 | 09:41 AM
excel8927's Avatar
thanks man appreciate it
Old Jan 19, 2011 | 02:29 PM
excel8927's Avatar
got it fixed, it was the ignition switch, but only the round part on the back of it, found one on a 1980 datsun 310 at a junkyard. amazingly all the electronic connections are the same! even the combo switch was exactly the same, a part that i paid $350 for 6 months ago
f1race79
Jan 30, 2010 08:32 PM
passaphist
May 23, 2007 02:21 AM
aesthetics
Jun 2, 2006 11:19 PM
FireDhusky
Jul 19, 2004 11:34 AM
Mjollnir
Jul 13, 2001 10:48 AM
