Swap Wiring question
1 Attachment(s)
ok im not that good at reading wire diagrams so.
1 is from a 81 automatic turbo engine harness 2 is from a 79 280zx manual body harness i belive this is located right next to the battery obviously they dont clip together the 81 clip has 5 wires i belive the 79 clip only has 3 i was wondering do i have to swap all the body harness wire from the turbo like were #1 would connect to or, do i splice those wires and wich ones would i connect for the turbo to run? |
Originally Posted by Male
(Post 322626)
We will help you, but only if you can help yourself too. A quick FI and ignition 280zxt to S30 turbo swap guide - Turbo/Supercharger - HybridZ |
well ive bin looking at my haynes manual and it is the to efi but it does not tell me what the colors mean
What the colors mean? The wires are different colors so you can trace them.
Well I was able to trace the turbo wires but not the 79 n/a
sounds like your almost there.
what are the wires you traced back to on the 81t harness? im betting your going to end up jumping some wires along the line from auto to manual wire harness swap. you just need to figure out what those 5 pin wires and 3 pin wires are. i had to do the same on my Z31 auto to manual swap. |
Yeah that's what I'm haveing trouble with finding what they are and I'm not even sure I'm looking at the right clip on the wireing diagram
1 Attachment(s)
You either need the other side of that plug that goes through the right inner fender, or you chop that plug and splice in the wires as directed in the diagram. I SERIOUSLY CANNON EMPHASIZE ENOUGH THAT YOU JUST NEED TO SIT DOWN AND STUDY THIS STUFF FOR A FEW MINUTES... JUST READ THE SWAP GUIDE...
https://www.zdriver.com/forums/attac...agram-swap-jpg https://www.zdriver.com/forums/attac...1&d=1363405538 |
