Stronger Exhaust Smell?
Old Mar 20, 2006 | 04:50 PM
duowing's Avatar
NisTuner
I've barely driven my Z lately, due to the continous crap weather going on, but I've moved it out of the garage and back in a few times. Did an oil change, etc. Anyway it seems like the exhaust has a more potent smell than I remember. I hope it's not just my Z31 injectors crapping out on me. Anyway I do have a vaccum leak going to the charcoal canister, the line is pretty much torn through, it got wedged behind a pulley and the pulley cut through it. My question is, would that vaccum leak cause a more potent smell or am I just coming up with reasons to avoid something worse.
Old Mar 20, 2006 | 07:13 PM
jfairladyz's Avatar
Might just be an exhaust leak. The cold weather can do that until the exhaust warms up. Or the cold weather could just be causing a really rich mixture which will also cause a stronger exhaust smell.
Old Mar 20, 2006 | 07:20 PM
duowing's Avatar
NisTuner
cold weather can cause an exhaust leak? That's true too, I didn't think about it running a bit richer when it hasn't started in a while or been colder, but will the the vaccum leak cause anything?
Old Mar 20, 2006 | 07:41 PM
jfairladyz's Avatar
Metal contracts when it's cold. As the exhaust warms up the metal will expand and seal any small gaps. It would be short term leak that would go away once the metal has heated sufficiently. Yes a vacuum leak can mess with your mixture. But it would generally only be at idle. If that line is torn and the canister is not allowed to evacuate its stored vapor to the intake manifold then it could just be venting to the atmosphere. Are you sure it's not fuel vapor mixed with exhaust that you're smelling?
I personally think it's just the cold weather and the fact that the car has been sitting thats causing your odor. If you suspect a problem though you should definitely investigate though cause it's better to be safe than sorry.
Old Mar 21, 2006 | 09:56 AM
duowing's Avatar
NisTuner
Bah, it could be one of my injectors is leaking a spec. It looks a little wet around the one injector. I had the car on, and was revving it a bit. It didn't look like it got anymore wet or anything around the injector, but it may be the very start of a leak? I guess I'll just fix that vaccum line, and keep an eye on the injector. I wouldn't be surprised if it's one of the 280ZX injectors I reused.
z_lis
40
Jan 28, 2008 10:06 AM
z_lis
13
May 30, 2007 04:02 PM
z_lis
Apr 24, 2007 10:42 PM
z_lis
16
Mar 12, 2007 09:19 PM
mr_z2001
Apr 13, 2003 02:36 PM
