Stock upgrade questions? Please help.
Old Nov 1, 2006 | 01:44 AM
Thaddeus280's Avatar
Talking Stock upgrade questions? Please help.
Ok. I have a stock 82' 280zxt. The only upgrades I have is a 3" exhaust (done before I purchased the car), and k&n air filter. I have been doing some reading and have found that the stock injectors can handle about 10psi of boost. I want to increase my boost to about 9.5psi so that I dont have to replace my injectors just yet. So to start, from what ive read i can get a manual boost controller and set it to such. I would also need to adjust my pop off valve to sustain the increased boost which i have learned can be done by adding a few washers above the spring inside. From what I gather, the internal components of the engine can sustain that amout of boost so there is no need for replacement of any of those. The only other thing that I should need is an after market boost guage that exceeds that amount right? Is there anything else that i must do to handle the increase in boost? Also if i were to add a small intercooler from ebay to the mix is there anything I should know or consider. Oh, and one last thing. Is there any reason to add a blow off valve with this modification? Any help would be greatly appriciated. Thank you!
Old Nov 1, 2006 | 04:04 AM
KTM200-280zxt's Avatar
Wow, your probably the first person who actually knows how the search, congradulations. As far as everything you said, your dead on. its definately safe to be running 10 psi. THe stock injectors can handle more then 10psi but I always like to be safe. Whats holding you back at that point is not having an intercooler. All you will need like you said is bost controller, boost gauge and plug or adjust the pop off valve.
As for an intercooler. Iv seen a lot of people using those ebay brand intercoolers and have really good luck, just ask around before you buy one. And you will NOT need a blow off valve, but once you install the intercooler then you DO need one. Once you get an intercooler you can run about 12 psi. At that point to get any more power out of it you will have to run some kind of aftermarket engine management system, Im using Megasquirt and thats really popular.
And the stock internals can handle way more power then the stock T3 turbo can even make, so I wouldnt worry.
Good Luck
Rob
Old Nov 1, 2006 | 02:46 PM
jfairladyz's Avatar
I think KTM pretty much nailed this one. Those cheap-o ebay intercooler should be fine for low boost applications. The junkyard is another option for an OEM quality intercooler.
A BOV is definitely not needed at 9-10 psi. You can use one if you want, but not needed.
And the internals are definitely the least of your concerns as long as everything is in good shape to begin with.
Old Nov 1, 2006 | 03:36 PM
nismo619's Avatar
u can block off the POV with a Plug from a hard ware store... u can raise the boost to 8psi thats what i recomand i haev a 1982 280zxt 5 speed i have raised psi to 7 8 9 10 11 ,12, 14, and 20 psi..on the stock turbo ... why 20 ? becuasei wanted to see if the stock turbo could take it.. in fact it did ! just not for a long long time.. i would tell u also to buy
1 NGk iridum sprak plugs <-- there kinda expensive but there the best..
2 degut cat or make a test pipe..
3 custom make your own cold air intake.. get ride of the old air box...
4 ADJ fuel pressrue regulator..
5. walbro after market fuel pump really helps out alot !
6.t/3t4 hybrid turbo charger... smile cuz u know u can turn up the boost and not leak !
7 is yours is a 5 speed... upgrade to a stage 1 , 2 or 3 cltuch and light flywheel...
8.. VLSD diff. ask nismopick about this upgrade.....
Old Nov 1, 2006 | 03:44 PM
jfairladyz's Avatar
I gotta say that trying 20 psi is just foolish. Of course the turbo can handle it. The engine and fuel system is another story. You're lucky you didnt put a hole through a piston at 20 psi.
Iridium plugs are a complete waste of money in an application like this. At 10 psi the stock NGK spark plugs are not hindering performance AT ALL. So why spend more on EACH plug than it would cost you for a set of six OEM? Mess with the gap before you spend more on sparkplugs then I did on an entire parts car
Old Nov 1, 2006 | 03:55 PM
No offense to Nismo, but listen to JfairladyZ he really knows what he is talking about. So dont go and crank your boost controller to 20+ psi!!!
Old Nov 1, 2006 | 05:01 PM
RodMoyes's Avatar
Doesn't post much...
Hey Nismo619... forget these guys!
Go ahead and crank your boost to 20psi and then go do one your famous reverse to first burnouts. It'll blow all the carbon deposits out of your engine.
Rod.
Old Nov 1, 2006 | 05:21 PM
Rod.
hahahahahaha
whatever happened to those reverse to first videos you were making. I say you go make another one, who else agrees?
Old Nov 1, 2006 | 08:49 PM
wreckedj30's Avatar
No Club Love
Originally Posted by KTM200-280zxt
hahahahahaha
2nded. i never saw that one...so do it do it.
Old Nov 2, 2006 | 05:52 PM
Ok. Sounds good guys. Thanks for the help. And Rod, what kind of rims are those?
Old Nov 2, 2006 | 05:58 PM
RodMoyes's Avatar
The 18" kind!!!!!!!!!!!!
Sorry, all other info regarding my wheelz is TOP SECRET.
Rod.
Old Nov 2, 2006 | 09:34 PM
nismo619's Avatar
Rod bought his wheelz from some back woods shop .. LOL i heard they came off a honda ? lol
p.s. i am famous baby " thats MR REVERSE to FIRST " to u ROD... LOL
Old Nov 2, 2006 | 09:52 PM
RodMoyes's Avatar
They are called "DrifZ" 515's 18x7...
And they are NOT off a pucking Honduh!
The also WILL NOT FIT without the right adaptors.
Rod.
P.S.
The day I call Nismo619 "Mr." anything is the day I slit my wrists with rusty razor blades and lie down in a nice warm bath.
Old Nov 2, 2006 | 10:37 PM
nismo619's Avatar
thouse wheelz are ugly... i must admit and there still honda... u trader...
Old Nov 2, 2006 | 10:47 PM
wreckedj30's Avatar
No Club Love
ugly i though you said he stole them from you...andwhere'd you get the spacers/ adapters. Cause those wheels are 5 lug, do a front end swap and posi...rod are you hiding things from us.
Old Nov 3, 2006 | 02:17 AM
RodMoyes's Avatar
Huh... this coming from the foremost authority on Style and Class!
Next thing you know, he's going to be telling us all about how to maintain a proper diet.
Rod.
Old Nov 3, 2006 | 04:03 AM
BigBirdsZ's Avatar
hahahahaha ^^^^^^^^ u crak me up lololol
Old Nov 3, 2006 | 07:10 AM
Purty S130's Avatar
Old Nov 5, 2006 | 03:42 PM
jfairladyz's Avatar
the example pic is 5 lug...Rod's are 4 lug. Look at his sig.
Old Nov 5, 2006 | 04:32 PM
wreckedj30's Avatar
No Club Love
what aboot bleaches, they look 5 lug...and i swear i did look at rod's and they were 5 but w/e you sure you didn't edit that J.
Old Nov 5, 2006 | 04:42 PM
mine are 4 lug! but they are custom wheels, bleachies are 5 lug, seen them in person, but he has fancy adapters
Old Nov 5, 2006 | 04:50 PM
wreckedj30's Avatar
No Club Love
your boyd's are 4 lug, thats cool, how much those cost by the way cause i like them...even though boyd coddinton is an *******, and i hate supporting him but there clean and i like them so eh. I'm going to upgrade my brakes and suspension with the z31's but thats after i get back to cali..since there aren't many around.
Old Nov 5, 2006 | 06:52 PM
the wheels were 2600 american, they were made in the mid 80's when the 280's were more common, he made only a few, ive never seen another set ever. the guy showed me his original bill for them. yikes!! and get this, they were designed by chip foose when he worked for boyd
zguy36
Feb 14, 2015 02:15 PM
KoolMan
Aug 23, 2012 12:15 PM
captken
Nov 30, 2006 05:28 PM
Dave Hamby
Aug 22, 2006 03:04 PM
Connors280ZX
Apr 26, 2002 10:12 AM
