Started DXing my dim headlight, and here's what I found..ideas?
So my left headlight had been intermittently going dim for awhile now. Even attempting to activate the high-beam doesn't do anything. Per another headlight thread, I checked the switch connector in the steering column to see if it's singed, but that checks out OK. So I did some electrical testing at the headlight bulb socket. The top (horizontally-oriented) prong-sockets is the ground, and the two side (vertically-oriented) sockets are positives, presumably one for low beam, and the other for high beam.
When I ran a voltage test on each of the side sockets, *both* were about 10.5V. Shouldn't only one of those sides be getting voltage? Does anyone have any ideas what would cause both connections to be receiving voltage simultaneously and so low (while the other side still works properly)? Where/to what do the wires lead to? I would've assumed the wires would go directly to the headlight relay under the hood, but if that were the cause, then the right side should be experiencing the same problem. So I'm thinking if there's something else the headlight socket wires lead to that could cause this sort of problem. I know I could rig up a new aftermarket relay for the left headlight, but I'd rather do things properly and find the culprit. |
headlight problem
Hello I'm new to this, but I hadthe same problem with my headlights. I also checked for the burnt connection, which turned out fine. Anyway to make a long story short, I removed the two screws which where the switch pins are cleaned the contacts. They were covered with carbon, cleaned them off with my pocket knife alcohol and a q-tip, and a eraser. Hope this helps
Bam! New guy rockin into ZDriver with some good tips. w00t! :038:
Mike...how dare you come in and give good advise :018:
That is a good idea. |
1 Attachment(s)
It was only the left side, This was a very easy fix! Doesn't cost anything, except maybe 30 min of your time. I will try to attach a picture by Nismopic. Anyway the picture to the left shows the contacts, once you remove the two screws you can remove and clean the contacts.
Originally Posted by Heat Rave R
Was the problem you had with both headlights, or just one. I think if the steering column switch is at fault, both headlights will experience the problem since they're both connected to it. The really puzzling part of my problem is that it's only one side, and I can't figure what the left headlight could be connected to that the other side isn't.
Anyone else have any ideas about further diagnosing, or what the problem might be? I'm still wondering what along the the lines the left headlight connects back to that the right headlight doesn't. |
i was reading this while i was waiting for a activation e-mail
what kinda voltage are you getting off the alternator it self? |
it is probably the plastic square that pops out when you turn the switch there is 3 of them and the one that controls the headlights some times get dirt in it just take the 2screws off and turn the switch you will see the 3 plastic squares pop out just clean them I was having the same problem and I I cleaned all the connections and the problem came back about a week later then I noticed the plastic squares turn the switch off they pop out and turn the switch on and they pop in .try cleaning them.I cleaned them with a Q-tip they are working fine now .but if I have that problem again I will order the relay harness from Black Dragon I had posted on this harness a couple of weeks ago I guess it does work. Just look at the thumb nail posted on #6 reply look at the connectors you can see the plastic squares.
In case you have not done this already, check the fuses. I had the same trouble and each headlight had it's own fuse, in the main fuse block on the passenger side. Cleaned the corrosion off, then both lights worked equally bright.
relays?
10 c |
