Stalling problems???
Old May 28, 2005 | 09:41 PM
Ryan82ZX's Avatar
I have an 82 280ZX with a manual transmission and every once in a while the car will just die on me and I don't know why. It does this at any rpm's and any temperature, but it seems to do it more when I push the car harder? Also, sometimes it will restart itself simply by leaving the clutch engaged and other times I have to turn the ignition off and restart it myself So if anyone has run into this problem please give me some suggestions. This one is a real stumper for me! Thanks, Ryan
Old May 29, 2005 | 02:04 PM
jfairladyz's Avatar
Could be your ignition module, common cause of this problem. You could have a bad connection somewhere in your ignition wiring too. Check those out. I had that problem and it ended up being the IM.
Old May 30, 2005 | 10:43 AM
Ryan82ZX's Avatar
Thanks, I'll try it!
Old May 30, 2005 | 02:42 PM
jfairladyz's Avatar
Oh, yeah, just to be warned...
That Iginition Module is a sneaky bastard. So your best bet is to test with a known good one.
Testing the module itself is pretty hopeless. Doable, but the other way is a sure fix method of knowing.
jrlogan280z
May 8, 2010 08:23 AM
drftrzx
Aug 29, 2008 07:06 PM
KevinH
May 16, 2006 11:14 PM
forcedfedz32
Oct 1, 2005 06:19 AM
