She go Put Put Put Puuuut, Silent
Old Apr 27, 2006 | 06:30 PM
FubarI33t's Avatar
I went out bought the strongist Batt i could find(925 warm crank amps, 800 cold) If that ca't turn it over, it don't need to be turned over. Start fluid, and some other goodies. I got her to go Put Put Put Puuut, silent. So at least she shows some kind of life, and shows she is very Capable of starting. Ran out of day light, so wish me luck in mornin.
Old Apr 28, 2006 | 10:47 AM
skittle's Avatar
Taste My Rainbow
I Know How That Is You Finally Think Your Getting Some Where And You Run Out Of Daylight....
Old Apr 28, 2006 | 11:00 AM
FubarI33t's Avatar
Ok, So my injector's are clogged. I am pulling them to soak in paint thiner. Dropping gas tank for a good clean out. Replacing fuel filter's. How many are there? I know of the one in the motor bay, but are there anymore? and where are these?
Old Apr 28, 2006 | 05:02 PM
there is only one fuel filter in the engine bay fubar. if you got air, blow some down the lines while you got the tank out to get rid of any junk in the lines, just dont fart or light a match for a little while after doing that, all the vapours will be in the air.
Old Apr 29, 2006 | 10:35 AM
nismo619's Avatar
u can use air.. what i did was funky but it worked i cut off a valve stem off my bicycle stuck it up onto my air tank 40psi i didnt some home work and i flushed out " aired out " my fuel lines in my 280zxt..
