Sending units..Ive searched but no posts are like this one.
Old Jun 12, 2008 | 08:01 AM
dapper189's Avatar
Unhappy Sending units..Ive searched but no posts are like this one.
So when i search the threads for "sending unit" i get some stuff but not a lot and no specific answer. Heres the situation. I now have my rail system hooked up and ready but when i turned the key i got nothing. So i posted, and received many replies, thanks you all, and as it turns out the fuel deliver system was worse than i thought. Were the fuel tanks lined with some kind of rubber or something? because i literally had tar or something like it in the inlet side of the pump and after i pulled it and let the fuel line dangle overnight i seriously had a puddle of tar under the car. So, after that i decided to drop the tank. not as hard as i thought but i wish some one would make a double deep well 14mm socket to make life easier. Got the tank dropped and needed to take a look inside. i pulled the sending unit and almost puked . What had been under the fluid line was coated in tar and what was above the fuel line was completely rusted. Now that you have the back story heres my question. I have decided to go with a fuel cell, i want to strap it underneath where the old one went if possible, but who knows how well it will fit. the problem is the sending units that come with the cells, they all say GM style 90 ohm. I'm guessing that our sending units weren't even close to that style or ohmage. so where do i go from here? I know anythings is possible with enough $$$ but I'm trying to do this as cheap as possible, so ebay fuel cells with sending units are my only option.
Old Jun 12, 2008 | 08:07 AM
280zx2by2's Avatar
Haterade by da gallon!
wow, do you have any pics of the tar, i havent seen any in my fuel system, im probly very very lucky...
as for the fuel cell i have no idea, but there are those hardcore racers like snw pick and bleach that will know something.....
Old Jun 12, 2008 | 08:08 AM
Just a guess here, but does Summit racing (.com) sell generic fuel gauges for a GM 90 sending unit? I bet they do.
Maybe not what you had in mind, but a separate fuel gauge is better than no gauge and would probably be the easiest to set up. Just run two thin wires up to it.
...and I'm not a hard core racer.
Old Jun 12, 2008 | 08:36 AM
dapper189's Avatar
I will post pics next week, my parents are staying with me for the week so i don't get to play. I had considered the fuel gauge for a GM, i had also considered no gauge and just use the trip odo.
Old Jun 12, 2008 | 08:46 AM
dapper189's Avatar
http://store.summitracing.com/partde...5&autoview=sku
http://cgi.ebay.com/ebaymotors/fuel-...m150255931634&
or
http://cgi.ebay.com/ebaymotors/16-ga...spagenameZWDVW
Old Jun 12, 2008 | 09:40 AM
280zx2by2's Avatar
Originally Posted by Bleach
up to it.
sounds like something a hard core racer would say...
Old Jun 12, 2008 | 10:42 AM
hey! I've got my street rep to protect. Don't give away my secret identity...
Old Jun 15, 2008 | 06:56 PM
jmmorriso's Avatar
just get a used tank from the junkyard or have yours boiled out. Save lots of time and money, plus a racing 20 gallon or larger cell will probably be too tall to fit under the car and be safe.
Old Jun 16, 2008 | 11:55 PM
duowing's Avatar
NisTuner
Bleach is only interested in a 10 second car.
Did the car sit for a long period of time before you owned it?
Old Sep 22, 2008 | 12:17 PM
dapper189's Avatar
Yeah a good 6 years or so and this is what confuses me, the guy i bought it off of owns a few chevelles and some nicely restored trucks, he knows how to store a vehicle but before he stored my Zs he replaced the tires and filled the tanks then left them to sit. WTF.
Old Sep 23, 2008 | 07:42 AM
the tank prolly was coated at some point and letting it sit detached all the goo from the insid eand caused the problems. i found sometimes boiling it out doesnt work, these tanks have a plastic baffle in them that makes it hard to do properly, the plastic will melt and cause new headaches. fuel cell wont be that hard, just new mounting and fuel filler stuff. then just make sure you hook it up correctly for fuel injection. most are good for carbs, so look into it, you may need a different tank or sender unit.
Old Oct 12, 2008 | 03:28 PM
wondermutt's Avatar
If you're interested , I have a tank and sender unit for a 83 zx turbo, the car sat for 4 years, but the tank looks clean inside the gas is a little orange but there was only about a gallon in it when it was parked. I'm in California and I'd rather part the car out instead of letting it got to the crusher.
this_is_lettuce
Sep 26, 2013 09:12 PM
Tsuka89
Oct 16, 2012 07:46 PM
mikesz
Jan 25, 2009 03:50 PM
nismo613
24
Aug 23, 2005 09:15 PM
