S130 Spring dimensions
coulda found this out in the FSM on xenonS130...
Front diameter
150mm/5.91"
Front free length
311mm/12.24" (coupe)
320mm/12.6" (2+2)
spring rate: 2.26kg/mm or 126.6lb/in
Rear diameter
100mm/3.94"
Rear Free length
353.5mm/13.92" (also listed for GS130)
361.5mm/14.23" (this is a second listing, says it's for a S130J)
spring rate: 2.51kg/mm or 140.6lb/in (coupe)
2.67kg/mm or 149.5 (2+2)
Front diameter
150mm/5.91"
Front free length
320mm/12.6" (2+2)
Rear diameter
100mm/3.94"
Rear Free length
