red light dash. wont turn green
red light dash. wont turn green, when i turn the key us it would of turn red then green to start.. but now it just stays on red and wont turn on.. does this mean something is wrong with the ecu or something with the motor?
please help if you know about this |
this happened after i saw water coming out the dash.. so idk if the water from the water crock got into the ecu, if that is possible
read the book means something isn't passing the test
Originally Posted by rogerz
(Post 313842)
(Post 313843)
Originally Posted by datsuns130
(Post 313837)
Originally Posted by FricFrac
(Post 313858)
Press the button....
THE ONE NEXT TO THE RED BOX! :023:
aye aye aye... |
if you do a google search on the web you will find downloadable drivers manual and fsm. hint xenon
(Post 313863)
aye aye aye... |
(Post 313863)
aye aye aye... |
Uberfacepalm3ooo! :icon_pidu:
That happens to mine to it says battery and I had it checked at autozone and they said it was ok I replaced the positive because it was cut up the negative looks fine what do I do?
Some early 79-80 280zx's and the Canada 280zx's have a battery water gauge. Once you replace the battery, it will trip that sensor since no modern batteries have that spot for the sensor. I would assume you could just disconnect it since it's grounding out... but I've never seen that sensor (you could look it up in the FSM).
Ok thanks
| All times are GMT -7. The time now is 01:02 AM. |
