Radiator ??? 1979 280zx
Old Dec 4, 2011 | 12:03 PM
spencer.m.mille's Avatar
I have a 1979 280zx and on the way back from work engine over heated so i pulled over let it cool off and then added water to radiator and oil in the engine rode for like 10 mins had to refill the radiator but after that i rode for 30-40 mins back to the house and it over heated like the first time with loud ring and hissing sound when i got out of the car. whats somethings i can do to check if i have to replace the radiator or what?? anything will help.
Old Dec 4, 2011 | 04:54 PM
87pyro3's Avatar
seriously????
ok well fill the radiator plum full
turn on car
find out wer the leak is from
hoses, pump, radiator, radiator cap
the leak will b obvious
if no leak is present then in in the engine and you need to check your oil for oil water mix
there is a company on ebay that sells a solid aluminum radiator for a decent price not a bad upgrade if you have to replace it
Old Dec 4, 2011 | 05:34 PM
WanganDevilZ's Avatar
The Emblem Thief y0!
If it is your radiator leaking, not much you can do but replace it.
http://www.thezstore.com/page/TZS/PROD/16-6959
More than likely, if it's "Hissing", you have a leak in one of your hoses, as I presume some coolant lines are still there from the factory, and are starting to crack
Old Dec 4, 2011 | 06:22 PM
ok well thx ill check it out in the morning i just really hope it is a hose. ill let you know how it goes.
rocky_dogtown
Apr 6, 2014 10:34 PM
Jason280ZX
Dec 31, 2013 04:11 PM
rabbit55
Nov 24, 2010 11:03 AM
81 Black L28E
Jun 27, 2005 12:09 PM
ozzy 79
Oct 11, 2004 11:37 AM
