Quick reply needed
Old Jun 26, 2011 | 02:39 PM
lv280zx's Avatar
Quick reply needed
Fuel line from pump to hard line broke. About 8 in long. When I was down there I saw something that looked stock and was not connected. Kind of looks like it should connect to fuel line. Cylinder shape with hose connection tube on both sides. Between pump an hard line. Maybe a filter? My 82 is very stock, so I don't think it's aftermarket. Thanks for quick replies
Old Jun 26, 2011 | 03:02 PM
lv280zx's Avatar
Apparently is the fuel damper. Does this need to be replaced or can I just bypass it, like the previous owner did?
Old Jun 26, 2011 | 04:17 PM
If it's been running all this time without you knowing about it, I'm sure it will be fine.
Old Jun 26, 2011 | 04:38 PM
lv280zx's Avatar
Thanks. I've had the car about a year. I did bypass it. Read up on the damper. Purpose seems to help FPR. Not sure how, if any, it affects performance.
Old Jun 26, 2011 | 05:13 PM
Skully's Avatar
from what I have read about dampers, its to prevent pulsation in your lines due to injectors draining the fuel rail and your pumps pushing fuel in so to speak, i doubt its that noticeable but some people have reported vibration without it in the lines.
91Zman
Aug 2, 2006 12:20 PM
HDPD350Z
Dec 30, 2005 06:47 AM
Skully
Aug 31, 2005 09:09 PM
EZDUZIT
Apr 2, 2005 11:33 PM
Spudz
May 29, 2003 01:36 PM
