oil
That may be a little too much. I'd loosen the drain plug just enough to let the oil drizzle out. Make sure you put the drained oil in a clean continer, 'cause if you remove too much...you can always put some back in without buying a new quart.
i think half a quart isnt too bad... you can get away with it... but if you want to take a half a quart out... you can take out your oil filter and drain it... theres bout a half a quart in there....
