Odd L28 engine
Ok I've decided to use that odd engine I have but maybe you guys can help me figure this out.
First this off is its a N42 Block, P79 head. Now it gets worse. It has mismatched pistons. From Front to back. F54 N/A Flattop, Turbo Dished, N42 N/A Dished, F54 N/A Flattop, N42 N/A Dished, Turbo Dished. On top of that the balance weights on the crank seem to have been machined down a bit. their shiny like brand new metal. nothing but the cylinder walls inside the block is that shiny. Any ideas as to WTF is going on with this L28? Im going to use in my Z till I can get the money to get my real L28 rebuilt. (DDing a old truck SUCKS I need my Z) Pics soon once my Camera decides to charge. |
4 Attachment(s)
Pics!
Back half Attachment 20884 Front Half Attachment 20885 Crank Attachment 20886 Close up Attachment 20887 |
have you ever run it before?
Originally Posted by skib
(Post 268627)
slap her together and run it, just make sure the timing chain is on %100 correctly and it should be fine for keeping the Z up till the other motors done
Sense it ran I kinda figured that much. And the P79 head it has is 100% new which is really amazing.
Anyways still no idea on whats the deal with this engine??? |
thats some nigged shit right their! :D but **** it, run it!!!!
lol that was someone assembling it from what was laying around.
**** it, itl work tho |
Ya then blow up 100 miles later? lol
What i want to know is why they machined the crank? To make it lighter? I hope this thing is still in balance. |
(Post 268641)
(Post 268644)
long as its balanced you dont have to worry about anything, thats why i asked if you had run it before
(Post 268645)
Well it ran like crap. but I knew it was way out of time. The lifters might not even be adjusted right yet. Oh well Now to get a headgasket and see if I can sneak by, by reusing the old headbolts lol
(Post 268648)
thats fine tho, just make sure your timing chain is on correctly and your dizzy isnt 180out and a valve adjustment takes like 10min. give the head bolts a little extra torque to make up for stretch and call it good :023:
good luck bro!
id run that. diff. pistons only matters if your building turbo, or high comp engines. for a daily, who cares. id make sure the t-chain is not stretched and put it back together. those are factory machining marks. thats as stock crank from what i see.
Ok Ordered the new felpro headgasket set. and the engine head would head off to the machinist but it looks too new so Im just going to spray it down with solvent and check to see if the head is still flush. I might get fancy and paint the block dunno lol I dont think that engine will last very long IMO
Those old headbolts are kinda scaring me a bit...
**** it! just slap a head gasket on it, run some head bolts you have laying around and use a head that isnt completey ****ed! :D just slap the turd together and run it until the pistons are one with the block, or you have a few rods out the side of the block!!!!!
datsun headbolts dont stretch much, ive re-used them a few times with high compression even. they are old school steel, not this new softer stuff
Well just waiting on parts. Im going to clean the block up and get it ready for some paint while I wait
Do the pins come out of the fly wheel so you can turn the entire thing? Or do you just machine down where the clutch disc actually touches?
just take them the clutch and flywheel and have the flywheel turned and then balanced.
Originally Posted by hoov100
(Post 268946)
Blocks clean, head is getting clean and so is the timing chain cover.
I got bored so I cut off the EGR part of my intake manifold, and my luck the angle grinder kicked back and made the cut uneven, oh well time for the dremal! |
GOT MY GASKETS IN! Tho I just noticed, that the head has cooling holes in it that the headgasket and the block doesnt have, but I can see on the block where they should be, Think I should drill them out or will it be ok?
And I got the headgasket for a 83 N/A |
