new guy 79 280zx
sup Z I recently bought a 79 280zx from some idiot ... this kid fried up te starter nd fuel pump ...
issue here is that the car keeps cranking nd cranking I installed new sparkplugs pigtails starter fuel pump clean the injectors fresh gas oil nd coolant as well new bridgestone tires and new hydraulic e brake with new double caliper In the back for better slides anyways im new to the z world but not to the ratsun forums ... people say it could be the battery but fresh battery the alternator and cap and rotor are new .. plz help thanks:fplasma: |
Have u washed the engine ?
The Throttle Position Sensor is pretty sensitive to water, it can sit in the connector and short out your system. Check all your engine bay connections, next to the thermostat is a group of sensors and connectors. Since you changed the fuel pump, what is your fuel pressure ? Do you have spark ? Have you checked all your fusible links ? A fusible link can burn on the inside, melt the wire completely and leave the plastic cover in tact, that is part of the design, so test them with a volt meter, make sure you have continuity. Hopefully it is something simple, because you have replaced a lot of parts and done a lot of work for it to not run for you.
Have you tried speaking to it romantically like its a woman, she might respond ! |
Originally Posted by PredatorZ
(Post 332225)
