Need help
Old Jun 6, 2005 | 10:03 PM
Skully's Avatar
im gonna lean towards a timing issue here
have you checked that its timed properly?
Old Jun 7, 2005 | 03:17 AM
I can tell you the firing order. 1-5-3-6-2-4. Going counter-clockwise. Starting at the F inside the cap. Hope this helps. Yeah and it is possible your timing is retarded a little. Try moving it one way, and see if it changes any. If not go the other way. I am pretty good at stabbing the distributor. Just by ear. Anyway congratulations on your new Z. Hope you enjoy it as much as we enjoy our Z's!
Old Jun 7, 2005 | 10:29 AM
81 Black L28E's Avatar
timeing is a good thing to check like they said, but i would check your rev control box its at the front of the intake little black box right on the driver side you mite have to change that out ./..also i would check all of your injector clips if one is not on just right it can make a wierd miss take a screw driver and put it to each injector put your ear to it and see if you hear each injector clicking .if you do then you golden but if you dont ,,change the bad ones out ..it could also be you air fuel mix turn the ajustment srcew on the front driver side right behind the rev control box ...hope this helps
Old Jun 7, 2005 | 02:56 PM
jfairladyz's Avatar
I was going to mention something about the distributor, but theres not a stator/reluctor setup on the turbo engine and the ECU controls the timing I believe,so you can't adjust timing with distributor. But I'd check it to make sure it's right. I'd go with the injector wiring mentioned above, and make sure your firing order is correct.
I had a similar problem on my NA, I had to drive it 10 miles on the freeway at about 1800RPM. And that's in SoCal, I've never seen so many birds . It ended up being my ignition module. Sometimes it would kill the car completely, but on this particular occasion it only made the car stutter like it hadn't completely broken contact but was on the verge. I replaced the coil, plugs, cap, rotor, wires to no avail. So I replaced the IM and haven't had a problem in almost two years.
It did not however have that revving problem but that one time, so...
