looking to buy this 280zxt with some problems
1983 Datsun 280ZX Turbo
this person near me just posted his 2800zxt but says it has issues running for extended periods of time. anything i should consider? |
It actually seems like a solid car at a decent price. I mean, it's going to have issues but it looks like a solid body and it does run apparently. I would just be sure to have a good bit of backup cash after buying it opfor anything that needs to be done.
Try getting him to accept a lower price.
Check: Vacuum lines Seals Plugs Wires |
ok, so when checking vacuum lines, do i just look for cracks, and where would be some not so obvious places?
thank you |
Originally Posted by conm4n
(Post 327354)
thank you |
pics of vacuum lines
5 Attachment(s)
These should help you find the ones on the front of the motor.
update on the 280zx
so i went and saw the car this morning and talked to the guy, he started it up, it idled normally, he spooled it up in the driveway but and i didnt notice any irregularities. i asked about the stalling issue and he said that the ECU might have cracked circuitry and id have to get a new one. what are the chances of this happening?
More likely a harness wiring issue or sensor issue. When the ecu is toast, it usually doesn't start.
what if the cracks were only minor and only opened up when overheating?
when the car idled i didnt see a check egine light which should've gone off if a sensor is bad. |
(Post 327424)
ok, theres a red dash in the light thats unlabeled because he swapped out the speedometer. but im thinking its the airbag light bacause the steering wheel is non factory as well. so if im going to have to check the continuity for these relays wheres a good place to get a decent multimeter?
it has now come to my attention that there are no airbags.
(Post 327428)
(Post 327427)
so I asked if he could hold the car over the winter for me if I put some money down. If no one else gives him a decent offer for the car, I'll have a new Datsun come late february
Originally Posted by Twiggs280zx
(Post 327359)
Originally Posted by FricFrac
(Post 327673)
We need to add this to our 280ZX reference web page we haven't made yet :)
