Looked everywhere! 280ZX Quarter Window Weatherstrip
Old Jun 22, 2013 | 03:52 AM
Stukinit's Avatar
Hi guys, I already searched and could only find posts referring to earlier model zcars, but I was wondering if anyone knew where to get the rear quarter window weatherstripping?
Or if not, then a good material/process to make your own weatherstripping? They leak only slightly but it's enough to make me want to change them, as you can see the super cracked rubber behind the glass...
Old Jun 22, 2013 | 06:01 AM
mikeatrpi's Avatar
Its butyl adhesive and is sold in rolls. Not sure if this is the correct way or not - but I used a heat gun on the inside to soften the adhesive and remove the glass. If you just pry at it, you could break the glass.
Old Jun 22, 2013 | 06:26 AM
Pipsqueak's Avatar
I called a glass company. it was only $50 to have it professionally, and no leaks since then.
Old Jun 22, 2013 | 08:11 PM
Stukinit's Avatar
Hmm I'll look for that then, I imagine a hairdryer would work just as well, it'll just take longer...
I swear MSA/BDA etc could make a good bit o' cash if they offered something pre-made for this situation.
Old Jun 22, 2013 | 08:38 PM
Stukinit's Avatar
Btw that is a beautiful ZX you have there mikeatrpi, lots of work has gone into that I imagine...
Old Jun 23, 2013 | 10:36 AM
MurphyEF's Avatar
Took mine out for tinting and used a heat gun and some vinyl panel poppers. Reinstalled with clear all weather silicone, which hasn't leaked yet.
Old Jun 24, 2013 | 11:41 AM
I did my own not long ago as it was leaking. I use a Olfa knife and kept the blade lubed with WD40. Replaced with a tube of Butyl in a calking gun. It's messy so wear glove. Clean up with a razor blade. Easy Peasy
Old Jun 24, 2013 | 03:26 PM
mikeatrpi's Avatar
Thanks! Like many here, its a labor of love...
7d82adz
Dec 30, 2015 07:32 PM
VernonZ
Sep 14, 2012 04:44 PM
dankfrye@charte
May 21, 2011 05:49 AM
atomicon
Aug 16, 2005 09:55 AM
CWHammer
Aug 14, 2004 05:16 PM
