Idler pulley bearing froze up, lost power steering.
Can i drive without the power steering working or will it fry my pump?
Need to be mobile to get to the bearing shop :\ |
If your pump isn't pumping because it's disconnected... it won't fry it. :D
You can leave the steering pump disconnected all you want... it's just harder to turn the car. |
ok, sorry, need some clarification. the pump is not disconnected from anything, its just not getting power from the belt because the belt is off. Does this constitute as disconnected or do i need to pull some hoses and stuff?
woot got a new bearing turned out to be a 6203. got installed used some sockets and a rubber mallet. As well as a bench vice. now to get it back to the car
you can drive it with no belt on it, that's completely fine, it won't damage the pump. I did that for many months.
I disconnected my power steering belt a few months ago. I got tired of it leaking fluid all over in my engine bay. Now I really don't miss it. I can turn the car just fine. And even one handed at times while turning a corner. :D
